Help With Interconnections
Discussion in 'Home Cinema Buying & Building' started by EL DOONUS, Jan 25, 2005.
  1. EL DOONUS
    EL DOONUS
    First Post...looking for some advice.About to purchase a Philips 37PF9946 and a Denon DHT 500.Will be using a standard Sky digital box.Wall is raggled and plasterer is coming at end of week so I want to have interconnections in place prior to him coming.Want to know the best way to connect these three bits of kit.Also if I need speaker cable other than that supplied by Denon.Prepared to spend a fair bit of cash but don't want to go over the top.Any advice greatly appreciated.The plasma has 1 RGB SCART,1 S-VHS SCART and one ordinary S-VHS connection.
  2. wicket
    wicket
    Nov 23, 2004
    493
    Middlesbrough
    +10
    Ideally you should use a scart splitter to the RGB input on the Phillips, thereby getting the best picture possible for Sky+ and the Denon.
    I found the speaker cable ample for my room which is about 22 x 12, rear two speakers on back wall, front two by the tv.
