Help with installing back speakers??
Discussion in 'Home Cinema Speakers' started by wynouk, Aug 25, 2003.
  1. wynouk
    wynouk
    At present I don't have a back speaker installed and I was thinking of installing another 2 Mission M7DS Surrounds at the back side walls as I don't have any space on the back wall (Patio Doors) the Denon amp has 6.1 but only 1 back speaker connection, Does anyone know of any way to wire 2 back speakers together ??or any other Idea's ?????
    Denon 2802 Amp
    Mission M74I Fronts
    Missinn M7C1I Front Centre
    Mission M70as Sub
  2. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +9
    Try wiring them in series assuming your amp will cope with the combined impedance, do a search and you will find discussions on this in other threads.
  3. morg
    morg
    According to the home cinema magazines theres no problem
    running two back speakers off of the one output they actually
    recomend doing that than just using the one speaker. If i remember correctly you just need a y splitter. Dont know about
    having them all on the side wall though it could maybe have
    negative effect on the sound stage.
