Help with INFOCUS 4850
Discussion in 'Projectors, Screens & Video Processors' started by George a L, Jul 4, 2005.
  1. George a L
    George a L
    Jan 9, 2005
    478
    43
    Scotland
    +132
    Hi, hope someone can reolve this issue for us, talked my brother in law into buying a projector so that he can watch football from the uk as he lives in the USA. So went out bought a infocus 4850 and connected it with the DVI cable it comes supplied with but when watching football over the internet the colours are bad like green is blue and if you are a celtis fan this is not good so any help would be greatly appreciated.\\Thanks :hiya:
  2. abspag
    abspag
    Check the menu for colour space and try the different settings this might cure the problem. In the UK. we have to buy the DVI. lead separate.
