Help with HTPC
Discussion in 'General Tech & Gadget Forums' started by awalner, Apr 26, 2016.
  1. awalner
    awalner
    Apr 11, 2016
    12
    4
    Chicago, Illinois
    I am a beginner in this area so please be gentle. I love this forum and have learned so much about a myriad of topics. I do not know if I am posting in the right forum
    Hello,
    I am trying to build put together a HTPC
    I am getting a projector (1080P) and a Marantz receiver (which has a solid DAC inside) and wanted to hook up my MSI Computer Corp. GT60 2OKWS 3K-615US 15.6-Inch Laptop to two 6tb hard drives mainly filled with music but has some movies, no gaming.I will hook this up through the receiver I will mainly use KODI, VLC and maybe plex. I had a few questions:
    1. Is this a good set up? should I do anything different get another computer- HTPC?
    2. Do i need another DAC if the receiver has one?
    3. I do have a Nvidia up stairs and a Gbox Q (not is use) but the problem is I do not think either box can handle 2 hard drives of this size at the same time. Can they?
    4. I take it running a USB cord to a product is much better than a NAS?
    5. Is there anything i should replace inside the computer?
    6. I take it I can use a harmony remote if I hook up an IR blaster to the Note book?
    7. Thank you so much I really do Appreciate it
    Below are the computer’s specs
    Screen Size15.6 inches
    Screen Resolution2880 x 1620
    Max Screen Resolution2880 x 1620 pixels
    ProcessorIntel Core i7-4800MQ
    RAM16 GB DDR3L SDRAM
    Memory Speed1600 MHz
    Hard Drive1024 GB SATA
    Graphics CoprocessorNVIDIA Quadro K3100M
    Card Descriptiondedicated
    Graphics Card Ram Size4000 MB
    Wireless Type802.11bgn
    Number of USB 2.0 Ports1
    Number of USB 3.0 Ports3
    Other Technical Details
    Brand NameMSI
    SeriesGT60
    Item model numberGT60 2OKWS 3K-615US;9S7-16F441-615
    Operating SystemWindows 7 Professional
    Item Weight7.7 pounds
    Product Dimensions15 x 10.2 x 1.8 inches
    Item Dimensions L x W x H14.97 x 10.24 x 1.77 inches
    ColorBlack
    Processor BrandIntel
    Processor Count4
    Computer Memory TypeDDR3 SDRAM
    Flash Memory Size128
    Hard Drive Rotational Speed7200 RPM
    Optical Drive TypeBD Burner
    Audio-out Ports (#)2
    Battery TypeLithium-Ion (Li-Ion)
    Batteries1 Lithium ion batteries required.
  2. wrench86
    wrench86
    Jun 18, 2015
    417
    north west
    +46
    that a few questions buddy but basically as long as the graphics card on ur machine has hdmi you should be golden, you will connect it to your av receiver (marantz) that will do all the audio processing if your going to be watching movies via kodi etc u will need to set kodi up correctly to enable passthrough audio. other than that a simple machine with a decent graphics card to output video at 1080p as your projector is limited to this resolution. now the specs u list will easily be able to do all of this. i used a laptop as a htpc but i found it annoying and just bought a dedicated mac mini to run as a htpc mainly caus its cleaner setup and dont have to faff with wires but obviously at an additional cost.
