This is my first post so sorry if I sound a bit dumb.
I have had an old PC for a while that I turned into a music jukebox. I have stored all of my MP3s on it and use album player to select and play albums. This all works great.
I want to expand the PC so that I can now store all of my dvds on the harddrive and play them through the PC. I am going to use DVD shrink to remove extras etc.
My idea is to make my own front end programme which will launch various programmes depending on what I want to do. I have a touch screen monitor which will act as a remote control.
My problem is that I have bought a Terratec 5.1 Fun soundcard with optical out to run the sound to my 5.1 amp. The only programme I have found that will pass thru the audio for true 5.1 is power dvd 4. I would prefer to use theater tec if anyone knows a way - I have tried the AC3 filter which didn't work. I have also tried MCE and have the same probelm with the audio.
What I would like to do is have a programme that will scan the hard drive for DVDs and allow me to download info / cover art to make a library. I know there are loads of programmes that do this but I haven't found any that I can use to locate the film and launch it using an external dvd player (power dvd 4). The only one close is DVD Lobby but there is no trial and I do not want to buy something until I know it fits.
Does any one have any suggestions for the software that would suit this.
Thanks for your help
