Help with home cinema setup please!
Discussion in 'Home Cinema Buying & Building' started by andystephens, Jun 24, 2004.
  1. andystephens
    andystephens
    Hi all
    I have a Hitachi TV that has a number of audio phono outputs on the back - front left, front right, centre, rear. However I'm not sure what home cinema surround hardware I can plug this into - everything I've seen takes either a scart or just two phonos as the audio input. What am I best doing? Are these outputs meant for some proprietory Hitachi amp (which I haven't come across)?
    I could go with some bog standard home cinema hardware, but it would require using that hardware's remote to a) switch source (tv, dvd, etc) and b) change the volume? (ok, so I don't want remotes littered around the room!) At least using the phono outputs on the TV I'm assuming that I could stick with using the TV remote?!
    Any advice greatly appreciated
    Regards
    Andy
