Help with hinge problem
Discussion in 'General Chat' started by Herbiefish, Feb 26, 2014.
  1. Herbiefish
    Herbiefish
    Jan 20, 2008
    2,302
    116
    Kent
    +573
    Has anybody got an idea of what sort of bracket I need to fix the gap at the top of the door above my fish tank? It was bespoke and the hinges and everything came supplied. When it came to fitting it I noticed the cover isn't flush with wall because of the bracket size.
    ImageUploadedByAVForums1393450553.260633.jpg ImageUploadedByAVForums1393450568.060707.jpg
    Problem is the company have since gone under so can't get hold of them and I have no idea what size of bracket or type i need. Think it is a concealed cup hing but I have no idea what I need to fix this gap. I have no idea what size this one currently is!!
  2. nheather
    nheather
    Oct 6, 2004
    19,763
    167
    Horsham, West Sussex
    +10,046
    Are you sure the hinge does have adjustment screws - I know it is a different type but hinges you get on kitchen cupboards, wardrobes etc. usually have 2 or 3 adjustments that can be made. They are very intuitive and it takes a bit of practice to get your head round how they work. But with those, it is surprising just how big you make the gaps if you adjust badly.
    The reason I ask is tyat I find it hard to believe that a gap that size is by design so I wonder whether the hinge is simply badly adjusted.
    Cheers,
    Nigel
  3. DavidMac
    DavidMac
    Aug 18, 2009
    1,321
    +271
    They're definitely Blum hinges, you'll be able to sort that gap fairly easily.
    With the hinge fully extended, like the first picture, look directly up and you should see an adjustment screw. Turn the screw so the top of the door moves towards the carcass.
  4. Herbiefish
    Herbiefish
    Jan 20, 2008
    2,302
    116
    Kent
    +573
    Thanks for the reply guys. I had a look yesterday and could not see any adjustment screws like on my kitchen cupboards. Will have a look when I get home. I really hope it is that simple :)
  5. gibbsy
    gibbsy
    May 17, 2007
    13,624
    3
    Cwm Cynon, De Cymru
    +7,611
    Standard hinge. Should be able to pick on up anywhere.
    I call my hinges. She's something to adoor.
  6. Herbiefish
    Herbiefish
    Jan 20, 2008
    2,302
    116
    Kent
    +573
    Adjusted the screw. Didn't make enough of a difference. Still large gap there. No idea what size of hinge I need now :-(
  7. True Romance
    True Romance
    Feb 7, 2005
    6,965
    Wolverhampton
    +3,031
    Have you tried searching Google images for your tank and looked if they all have the gap showing, might just be the way its designed?
  8. DavidMac
    DavidMac
    Aug 18, 2009
    1,321
    +271
    I would buy some Blum hinges from the likes of screwfix to replace them with.
  9. Herbiefish
    Herbiefish
    Jan 20, 2008
    2,302
    116
    Kent
    +573
    It is a bespoke in wall tank and a bespoke surround. I told them what I wanted it is just unfortunate that they somehow got the hinges wrong!
    Is there any particular size I should look for or are they all the same and I just happen to have strange set?
  10. Herbiefish
    Herbiefish
    Jan 20, 2008
    2,302
    116
    Kent
    +573
    On the hinge it says tev, made in Italy so I will have a google for that and see what I can find
  11. IronGiant
    IronGiant
    Jun 7, 2003
    66,494
    +46,702
    Theoretically you could move the mounting point of the hinges on the door down the necessary cm or so, but unless you have the right tools and the skills to do it I wouldn't recommend it.
  12. Herbiefish
    Herbiefish
    Jan 20, 2008
    2,302
    116
    Kent
    +573
    Yeah way above my skill level!
    I have taken it off and the box type part on the right hand side of the hinge comes off. So I just need to get one with half the depth and attach that to it I think.
    Tried a Blum hinge from my kitchen and doesn't work as the it needs yo sit inside the frame
  13. Herbiefish
    Herbiefish
    Jan 20, 2008
    2,302
    116
    Kent
    +573
    ImageUploadedByAVForums1393526139.300811.jpg this is the hinge
