Hi All,
This is starting to feel a little complex to me now but..... I have a Lyngdorf MP-40 that is a superb processor but is somewhat limited in terms of inputs and outputs (which IMO is crazy given what it cost!). I am currently using one of these to give me extra inputs:
www.futureshop.co.uk
It has been working well with no real issues. It is all being controlled using a Control4 remote system (which is complex, expensive and does stop working a fair bit but otherwise excellent!). I am now looking at adding a projector so will need an extra output.
So, should I add some kind of HDMI splitter for the output only or replace the Bluestream with something that will cover the extra inputs and also the 2 outputs? The latter feels cleaner but will probably be expensive I would think!
Any thoughts/advice appreciated!
Thanks!
Blustream SW41AB-V2 4-Way 4K HDMI Switch
Blustream's SW41 is a 4 input HDMI switch with integrated audio breakout. The switch supports all video resolutions up to and including 4K.
Thanks!
