Help with hdmi switching please
Discussion in 'Plasma TVs Forum' started by AV Monkey, Feb 2, 2009.
  1. AV Monkey
    AV Monkey
    Oct 29, 2006
    915
    28
    hampshire
    +39
    I now someone who just purchased the 42" version of my plasma in my sig. Problem they got is when they turn on the set it always stops on freeview.
    They have had a virgin v+ box installed connected with hdmi. Is there a setting in the virgin box setup menu so the tv will auto-detect the signal from the virgin box when its turned on?
    The guy is quite elderly and really hope i can help before he puts his foot through it as he is a technophobe and is getting really wound up with it.
  2. alffjeld
    alffjeld
    Jan 7, 2009
    103
    +10
    i think i have read that there are a hotelmenu on that tv.
    in there you can set what input to start on, try searching for hotelmenu, and you should find it,
