Help with gaming pc Rig
Discussion in 'PC Gaming & Rigs' started by 247gamer, Feb 18, 2018.
  1. 247gamer
    247gamer
    Sep 5, 2017
    4
    Everywhere!
    hi Guys
    I’m looking to start playing a few pc games like American Truck Sim and currently have a MacBook Air laptop which has the spec:
    Display
    • 13.3-inch (diagonal) LED-backlit glossy widescreen display with support for millions of colors
    • Supported resolutions: 1440 by 900 (native), 1280 by 800, 1152 by 720, and 1024 by 640 pixels at 16:10 aspect ratio and 1024 by 768 and 800 by 600 pixels at 4:3 aspect ratio
    Storage1
    • 128GB
      128GB PCIe-based flash storage
    • Processor
    • 1.6GHz dual-core Intel Core i5 (Turbo Boost up to 2.7GHz) with 3MB shared L3 cache
      Configurable to 2.2GHz dual-core Intel Core i7 (Turbo Boost up to 3.2GHz) with 4MB shared L3 cache.
    Memory
    • 4GB or 8GB of 1600MHz LPDDR3 onboard memory (8GB maximum)
    Graphics and Video Support
    • Intel HD Graphics 6000
    • Dual display and video mirroring: Simultaneously supports full native resolution on the built-in display and up to 3840 by 2160 pixels on an external display, both at millions of colors.
    • Thunderbolt digital video output
      • Native Mini DisplayPort output
      • DVI output using Mini DisplayPort to DVI Adapter (sold separately)
      • VGA output using Mini DisplayPort to VGA Adapter (sold separately)
      • Dual-link DVI output using Mini DisplayPort to Dual-Link DVI Adapter (sold separately)
      • HDMI audio and video output
    I was go No to hook up to my 4K tv to play but not sure if it’s going to be good enough so possibly looking at a pc that could run and play the games all fine
    Any ideas or will I be better sticking with what I have ?
    Obviously I’f I do buy a pc it will be basic enough to run the games so like £200-300
    Thanks in advance for your advice
  2. aslird
    aslird
    Sep 8, 2011
    6,098
    +4,284
    You will never be able to play games at 4k with the system you have. If you want "4k" gaming at your budget, buy a 2nd hand PS PRO or X Box X.
    Even at 1080p, ATS may really struggle with the system you have.
  3. 247gamer
    247gamer
    Sep 5, 2017
    4
    Everywhere!
    Sorry I’m not fussed about 4K just that y tv is 4K. Just need something so that the game runs ok on my tv
