Help with Freeview with Tosh 46" DLP and which DVD do I buy?
Discussion in 'General TV Discussions Forum' started by cpj, Jan 7, 2005.
  1. cpj
    cpj
    I have 90% made my mind up to buy the Tosh 46WM48 DLP. Can I get a good picure via Freeview or do I need to go SKY+.
    Also why have a lot of you gone for the Pana S95 and not the Den2910?
    Is it just down to price?
    Great forum!!!!!!
  2. lee31
    lee31
    I have Tosh & standard Sky installation & get a cracking pic althoug my signal strength is over 50% which I believe is pretty good
    Re Panny S97 & Denon 2910, I have Panny & it is a superb player & as for my reason to buying it over Denon, yep price, I paid £259 (delivered) for my Panny whereas Denon is around the £500 mark
    Hope this helps
    Lee
  3. dalespitfire
    dalespitfire
    Dec 3, 2004
    619
    +8
    I've just got the Multi Region Panny S97 for £207.95 delivered from TopTelevisions.co.uk :D
    Did notice the price is up to £229 less than an hour after I bought it though..... :eek:
  4. maidstoneman30s
    maidstoneman30s
    Apr 21, 2004
    155
    16
    not in maidstone, hehehe
    CPJ,
    I have just posted some pics on my thread Tosh 46WM with S97 test tonight.
    The DVD is gladiator.
    I paid £259 for multiregion from Digital direct.co.uk
    More than others, but i was in a hurry to get it.
    Hope this helps
    maidstoneman30s
