Help with 'freeview' recording on Panny PE30
Discussion in 'Plasma TVs Forum' started by Seanjackdan, Sep 3, 2004.
  1. Seanjackdan
    Seanjackdan
    When I set up a DVB (freeview) timer recording on my PE30 Plasma, it always automatically starts recording on the DVD part of my DMR-E75 recorder.
    I have Q-Link enabled.
    I have read the manual, and I can't seem to work out how to get it to record on to the video part of the DMR-E75.
    Any help would be appreciated............
    Sean...........
  2. Orlando
    Orlando
    Feb 2, 2004
    158
    Essex
    +5
    I think this will be an option in the DVD menu and not the PE30.
    It's doing it's bit, there is no way it would know whether to record to DVD or hard drive.
