jason g
hi,
im in the process of making some av and storage units etc from 18mm mdf, however my bedroom floor and walls are not right, the walls i can deal with ok but the floor i need to level so does anyone know of a way i can level it, ive seen some adjustable feet i can buy but they are plastic and with having an lcd sitting on the unit i think they may not hold the weight, plus they are a bit tall so if anyone can advise me on a solution that would be great.
ideally i am looking for some heay duty adjustable feet for the tv unit but the plastic ones i saw below were 150mm which i would like to reduce but if not then ok but i really need to find some that can take the weight of the tv unit plus the tv itself.
thanks.
http://www.screwfix.com/search.do;j...A?_dyncharset=UTF-8&fh_search=adjustable+feet
thanks.
