help with flat cable
B
Bob Campbell
Please can some one advise the a good flat speaker cable. I intend to put this under the carpet running round the skirting board .
The system is as follows
Panasonic display
Sky+
denon avr 2805
tannoy arena speakers
suggestion would be helpfully , my lat posting for help was great I was trying to locate the avr 2805
many thanks
bob::lease:
Amar
I use Nordost's Flatline Gold MKII for my fronts. They're thinner than a credit card. I upgraded them from QED's Silver Anniversory Biwire and can say that the difference was night and day. Very, very good speaker cables imo.
I also bought some silver speaker cables from seduction audio that I found to be even better than my Nordost's, at a fraction of the cost. They aren't flat but are quite thin and very flexible. I now use them throughout my system and biwired with my Nordost's for the fronts.
Hope this helps.
B
Bob Campbell
Thanks Amar did see that cable thought it costly but you reckon it's worth the cost will consider both your suggestion thanks for the response.
best regards,
bob:arty:
Amar
If you're talking about the Nordost's, I'm not don't think it's worth the full rrp (as good as it is) now that I got the ones from Seduction.
I managed to get the Nordost's at a good price from ebay. Without the terminations, it's about £11-12 per meter but that cost goes significantly higher if you have them terminated. I got my 3 meter pair for around £50 terminated from ebay.
B
Bob Campbell
amar, have you an address for seduction sounds a better bet
bob
Pat Marcus
QED Silver Profile 12
Amar
bob
Bob,
Here's a link for Seduction. They sell on ebay but are totally trust worthy and give a good service. They are selling the speaker cable I bought on there at the moment although the price seems to have gone up some what.
http://stores.ebay.co.uk/Seduction-Studio_W0QQssPageNameZstrkQ3amefsQ3amesstQQtZkm
Normally, they give me a better price as I buy from them outside of ebay but it may be worth trying to haggle a little and try and get yourself a good deal.
Good luck mate.
B
Bob Campbell
thanks amar will check the site out your help is greatly appreciated
best regards,
bob:thumbsup:
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
