D
Dodgy Bob
Sorry if this has been asked before, I did a scan through the other threads but couldn't see anything that would help.
My problem is that I explained to the builder what I wanted and it didn't work out. I had a brick wall where the TV was to be mounted, but due to the amount of cables he wanted to put up a stud wall on it and then plaster. I marked on the brick wall where the TV bracket was going to be fixed and asked that he put studs where the screws were to go.
When I got home he had built the stud wall and plastered it. I've since found the studs and they don't line up with the bracket, they are too far apart. So I can either fix the top or the bottom of the bracket to a stud but not both. (I also asked him to make the stud wall as thin as possible as the room isn't too big, he said I would lose about 2". Ended up losing about 6"
What can you recommend for :
a) Should I fix the top or bottom part of the bracket to the stud, and with what?
b) What should I use to attach the other part of the bracket to the plasterboard with?
It's for a Samsung 46" LCD, the mount is a flat on the wall one with tilt.
Thanks for your help.
Bob.
Bob.
