Hey people
I'm looking to build my first pc and I just need some tips on what parts to use.
But, here's the catch: it has to cost under £320 and still perform reasonably well with games.
Here's the spec list I have planned at the moment:
CPU: AMD Athlon II X4 631 (Socket FM1) £66.22
CPU COOLER: Arctic Cooling Freezer 7 Pro Rev. 2 £15.98
MOBO: Asrock A75M-HVS mATX (Socket FM1) £49.29
PSU: Corsair CX430 V2 £34.23
RAM: Corsair 2X4GB DDR3 1333MHz £20
CASE: Fractal Design Core 1000 £28.98
GPU: Sapphire HD 6670 £77.03
Other stuff:
92mm Fan: £5.09
Optical Drive: £13.98
Wireless Card: £9.99
= £320.79
I only play a few different MMORPGs and Sims 3 and stuff so are these specs over the top, or are they not enough? I need to spend as little as possible.
Thanks in advance
Other stuff:
92mm Fan: £5.09
= £320.79
Thanks in advance
