Help with first projector
M
Mad1
I bought my first projector last week and i am trying to connect it to my lcd tv can anyone tell me if this is possible as i have had no luck yet.
chic
why would you want to do that? if its to get tv programmes on the projector the cheapest way is connect your vcr to it or directly run your sky ,cable or freeview box to it,
Member 55145
on some tvs scart 2 or 3 has an option to output so you could try that.
my old toshiba lcd and crt would output via scart 2 and had multiple options what you could output
M
Mad1
How would you connect your freeview through it if the freeview is built into the tele.
I will try going through the scart when i get an adapter.
Member 55145
in the scart options menu you get multiple options of what to output. you can either output another scart input, analoge tv, freeview tv or whatever your current tv is displaying
if you let us know what tv you have we might be able to help out more
andrewb150
Established Member
Even if his TV has freeview output on scart 2 wouldnt that mean that the tv would have to be switched on to change channels.
On my panasonic you can record from the built in Freeview by plugging the vcr to scart 1 or two, what ever you set it to in the menu. The box will change channels when timer events are set but otherwise it will not change channels unless the tv is switched on.
You may as well buy an external freeview box.
Klipsch The Sevens Powered Speaker Review Coming Soon
Back
