help with finding a seller to pricematch JL
Discussion in 'Plasma TVs Forum' started by m_felstead, Aug 4, 2004.
  1. m_felstead
    m_felstead
    Hi chaps
    I'm a long time lurker on this site..... mainly for xbox stuff.....and this site really is the dogs danglies ...
    after a month of research ( and begging the wife.... my knees are all blood !) I have decided to take the plunge and buy a Panna TH-37PE30.....but I want to buy it from John Lewis for the 5 yr warranty...problem is they want 2,895 quid.
    I'll be price matching with JL Watford....as brent X seems to have a bad reputation
    I'm not bothered about getting the absolute lowest price from a dodgy internet seller...I just wondered if anyone else had recently used a cheaper trader ??
    If I could get it for 2,300 I'd be pleased
    Any ideas ?
    cheers
  2. Yelpir
    Yelpir
    Jul 19, 2004
    17
    Ask them to match Sound and Vision - they are an online dealer but tell the folks in John Lewis to call their Bolton branch - this is a legit high street shop so JL should match and Sound and Vision do free delivery so that should also not be a problem
    http://www.soundandvisiononline.com/moreinfo/index.asp?product_id=4127
    £2179.95 and it's in stock
    JL Nottingham matched a Hitachi 42PD5300 with this place for me and saved me £405
    Yelpir.
