Help with DVD Profiler
Discussion in 'Movie Forum' started by electrolyte, Jan 31, 2003.
  1. electrolyte
    electrolyte
    Feb 3, 2002
    4,030
    Sheffield
    +1,077
    Can anyone help me with DVD Profiler? I have 2 DVDs that I got free with my DVD player - I have tried to enter them in on DVD profiler but they don't have a bar code so I can't enter them (they are promo copies). Tried entering them in by searching by title but this only brings up the R1 versions. The 2 DVDs are:
    The Full Monty
    Pearl Harbor (single disc version)
    If anyone has these DVDs would they be kind enough to reply with codes? Thanks.
    ps forgot to mention, both DVDs are R2...
  2. alle v
    alle v
    Nov 11, 2002
    211
    19
    Derbyshire
    ...Make sure that in your default properties that R2 is selected. then when you search by title it will find R2 versions.
    Its under tools/options/defaults.
    This will not necessarily mean yours will then be found though.
  3. electrolyte
    electrolyte
    Feb 3, 2002
    4,030
    Sheffield
    +1,077
    Thanks mate, should of thought of that! :blush: Did wonder why all the DVDs on the list were R1...
    Will look tonight....
  4. graham.myers
    graham.myers
    the full monty upc is 039036003018
    i 've got the same freebie
  5. electrolyte
    electrolyte
    Feb 3, 2002
    4,030
    Sheffield
    +1,077
    Thanks Graham, cheers.:smashin:
  6. Squirrel God
    Squirrel God
    No, that's not what you want to do as then you'll have the same problem with other regions.
    All you need to do is click the ADVANCED FILTERS button on the entry screen. That will open up some more options where you can pick which regions are displayed ;)
  7. alle v
    alle v
    Nov 11, 2002
    211
    19
    Derbyshire
    ...Still works though ;) ...especially when your method isn't known :eek: :D
  8. electrolyte
    electrolyte
    Feb 3, 2002
    4,030
    Sheffield
    +1,077
    Thanks for all your help, have now entered the DVDs into Profiler succesfully. Cheers!
