Help with DTS on Yamaha DSP-AX750SE
Discussion in 'AV Receivers & Amplifiers' started by shortone, May 27, 2005.
Tags:
  1. shortone
    shortone
    May 1, 2005
    115
    Nuneaton, Warks
    I have no brain, this must be said.
    I have the following
    Yamaha DSP AX750SE
    Pioneer 575A
    AE speakers but no sub.
    Problem,
    Playing DTS dvds but not getting DTS always getting DD on the amp.
    Connections
    DVD to AMP via componets and coaxial
    AMP to TV via componets.
    Checked settings on DVD and they look fine.
    from what I can gather the AMP is already set to acecpt DTS from coaxial on DVD input.
    Checked options on DVD for sound selection.
    Please help before I kick something.
    Picture of current set up due to rented house and not being allowed to place cables in the walls.
    Regards
    Andy
  2. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    You say you checked dvd options, do you mean the menus on the disc or the dvd player setup? check the languages on the dvd disc's menu's, there should be dolby digital and dts (on dts discs) as all dts discs default to the DD standard (they contain both DTS and DD tracks).
    Failing this check the dvd player's display and check it says DTS and not DD, if the amp still says DD (when dvd player says DTS) then something is very wrong!
  3. shortone
    shortone
    May 1, 2005
    115
    Nuneaton, Warks
    I have checked the DVD player and the menus on the disk but have no tried the languages menu. The DVD player is showing the Dolby sign with a D next to it which I take it is Dolby Digital. Just got to work so will try this tonight. Thank you for your responce.
    Regards
    Andy
  4. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,517
    Edinburgh
    +1,239
    Make sure you have the digital output on the player set to bitstream.
  5. shortone
    shortone
    May 1, 2005
    115
    Nuneaton, Warks
    A big thank you as all is well again.
    As this is the my first venture in to home entertainment I am clue less, but with the help from this forum I am getting better.
    I was unaware of the DTS option being in the language menu. I thought this was purely for forigen langauges.
    Kind Regards
    Andy
