Don Dadda
Hi all
This is my first foray into self build amps and the main aim is not to burn up the house but have something that works and works well. So chaps, especially those who have been there, done that already i am going to need all the help i can get
Long story short, I use a stereo amp for TV and music. I use to have an avr and 5.1 but then went to 3.1 when we changed the room layout and didn't want rear speakers in the only place they could go - the rear wall. I tried the speakers behind the sofa, 6-8" away from the wall but that ate too much into the room and I wasn't really that impressed with that config TBH. Music being the main priority, I'm ok with not having rear speakers so sold them and the AVR, but i do like a center channel for vocals as ts mor defined.
I am happy with the stereo amp but vocals do sometimes get lost hence me building a mono amp just for the center channel.
After much research and speaking with one of the team from hypex i have ordered the following bits from them:
1 UcD180HG with HxR
1 SMPS400A180
1 Cable set SMPS400
1 DSP - UcD signal cable
From the bay i bought a pair of speaker posts, a RCA phono socket, spacers and the chassis pictured below
Dimensions of the chassis is W150mm x H70mm x D280 approx. In the box of the chassis came mains socket, volume knob and on/off switch. The chassis is the size i wanted as i don't need a full size one.
The only thing i need i believe that is left to purchase is a heat sink but i thought i waint until the Hypex parts arrive before i do, so i know what size to get.
As said above, this is my first foray into DIY amps build and once i have all the bits, not sure how to go about designing the internal layout. Though it doesn't look extremely difficult to do, i would like some help/pointers from your good selves on which should go where.
I also would like to add in the volume control as some of the films i have watched, the vocals could do with a boost or reduction.
I will be using a Oppo 105 as a pre amp to the mono amp and my existing Amp in HT bypass (removed its links and stuck a analogue input switch in between the pre-and power stages)
Any and all help would be much appreciated
Thanks in advance
H
1 UcD180HG with HxR
1 SMPS400A180
1 Cable set SMPS400
Thanks in advance
H
