I’ve recently purchased a Denon X4700H and Sony Bravia A80J. I stream content using Google TV which is built into the Sony. The TV and receiver are connected via HDMI cord at their eARC ports.
The only external device is an Oppo DVD player which is connected to the “Blueray” port on the receiver.
I am having a volume problem with AVR. It will not get very loud when streaming through Google (i.e. Prime, Netflix, YouTube TV, etc.).
The Blueray portion works just fine. I have the ability to adjust the source level for the Blueray input but can’t figure out how to raise the volume for everything else since it is not connected to the AVR through an “input”.
Does anyone have a solution?
Additionally, I’m having issues getting Blueray video to show on the TV screen. It seems there are way too many button pushes to get Blueray to work. I have to press the “Blueray” button on the Denon remote and audio comes on. Then I have to press the eARC input on the Sony remote and then power off then on my Blueray player to get video to display on the TV screen.
Does anyone have a solution for this issue?
My Pioneer Elite SC AVR recently failed with a UE22 error and it was connected to a Panasonic Plasma. These components worked flawlessly together and the pioneer phone app was so much better than the Denon app. I now have buyer’s remorse!
Thanks for the help in advance.
