Help with Denon receiver sand crossover settings?
Discussion in 'AV Receivers & Amplifiers' started by micb3rd, May 18, 2002.
Tags:
  1. micb3rd
    micb3rd
    Dec 8, 2001
    1,047
    48
    Bedfordshire
    +67
    What is the crossover frequency between main speakers and subwoofer.
    It is changeable in all denon amps e.g. 40hz 80hz 100hz 120hz??
    1602
    1802
    2802
    3802
    Can anyone help me?
  2. micb3rd
    micb3rd
    Dec 8, 2001
    1,047
    48
    Bedfordshire
    +67
    OH and I have Mission M73 floorstanders and soon to perchace matching center and rears M7c and M7ds.
  3. bob007
    bob007
    As far as i know only the 28/3802 have changeable crossovers 80/100/120htz.
    If you have either of these models set speakers to small and set x over to 80hz.
    If you have either the 16/1802 set speakers to small, even though you can't set the x over manually it's already pre-set to about 80hz by the amp.
    bob
  4. infomatique
    infomatique
    If you visit the US site www.denon.com or www.denon.ca (Canada) you can down load manuals for all Denon Receivers (the US numbers may be different but it is usually easy enough to work out what models are equivalent)
