Help with deciding on a 40/43 inch TV (Possibly 49)
Discussion in 'What Is The Best TV For You?' started by Jspen, Aug 24, 2018.
Tags:
  1. Jspen
    Jspen
    Aug 24, 2018
    5
    Leicester
    Hi Guys
    I've been trawling the forum for a couple of days looking at all the great advice people give and receive - hoping I can drop a couple of questions in that suit my needs and see how we get on.
    I'm looking to upgrade my TV that I've had since 2011 - (Sony Bravia - unsure of the model) 40") -
    I don't have a set budget, however the models at the top of my list so far are <£500, but if there is a TV that far exceeds these sets that isn't a million miles away in price, I would happily pay more, as I tend to get my moneys worth with TV's.
    The two models I have in mind are the 40" Panasonic EX700, and the Philips 43" PUS6703/6753.
    I realise I'm not going to be getting the highest standard at this size and price point, so I would be willing to go up to 49/50" if there are TV's that far exceed these two options.
    Will mainly be using for movies and watching football. I will be sitting about 2-2.5m away from the screen, and I don't care about sound quality as I have a soundbar set up.
    Questions:
    -Are the two panels I've specified any good? The reviews seem solid, especially for the Philips.
    -If I increased to 49/50", will the picture quality be far superior?
    -What panels do you recommend, and why?
    Thanks in advance!
  2. zeppelino
    zeppelino
    Jan 24, 2018
    3,931
    134
    UK
    +1,205
    Could you go to 55”? More choice at that size.
  3. Jspen
    Jspen
    Aug 24, 2018
    5
    Leicester
    I just think 55" will be way too big for my living room, so 50 would be my limit.
  4. zeppelino
    zeppelino
    Jan 24, 2018
    3,931
    134
    UK
    +1,205
    Sony XE/F85 - XE is 2017 so may be difficult to find. Both at 49”
    Hisense U7A @ 50”.
    Panasonic EX700/750
    I would be looking to go up in size. New 40” will look small due to size of bezel.
  5. Angelo M
    Angelo M
    Jan 25, 2015
    576
    Terlizzi
    +79
    The Philips 50PUS6703 seems to be very good. ;)
    Philips 50PUS6703 review
  6. Jspen
    Jspen
    Aug 24, 2018
    5
    Leicester
    The only thing that concerns me with how bulky it sounds. 6.8cm depth sounds a lot to me, my current tv is about 3cm. The review sounds excellent though
  7. Dodgexander
    Dodgexander
    May 29, 2007
    15,208
    +4,407
    That Phillips will probably be using the same VA panel as every other 50" TV such as the Hisense 50U7A.. Many been suggested already.
    It's expensive compared to others, I remember people even picking up a refurb Panasonic 50EX700 for £350 on their eBay store.
    Thickness will be down to edge or direct lit, nowadays it doesn't really matter though.
