Help with DAB Tuner, CD Player and Speaker stand purchase
Discussion in 'Hi-Fi Stereo Systems & Separates' started by danielw, May 5, 2007.
  1. danielw
    danielw
    Mar 3, 2007
    23
    Hi Guys,
    I have just bought myself a Rotel RA 05 Amplifier and some B&W DM601 S3 speakers and now want to buy some stands for my speakers and a DAB tuner + cd player.
    I regards to the speaker stands does it make a difference to sound dependant on make? I am looking at either atacama or soundstyle ones would ones you get for £70 be alright or should i be spending more?
    With the DAB tuner I am half in mind to buy either the denon 1800 or go for a second hand rotel or arcam model is there a big difference in the quality of dab tuners?
    With the CD player what is better a cambridge azur 540 or rotel 06 series cd player? I demoed the amp and speakers with the rotel cd player and liked the sound but i have been told the cambridge sounds a bit better however i can't demo this as richer sounds don't sell the amp and speakers?
    Dan
  2. crowncd
    crowncd
    Nov 25, 2005
    151
    Can only comment on the DAB tuner aspect of your question. I've had the Denon tuner running for a couple of months now and think it's superb. I'm sure there are other excellent tuners out there. I do have both an external DAB and FM ariel - I'm sure this improves the reception quality.
  3. stevedster
    stevedster
    Jan 13, 2005
    1,132
    48
    Birkenhead
    +41
    Im in the same boat as you and after much research I will be plumping for the Denon TU1800 from Richers. As soon as next months pay packet arrives she's mine :thumbsup: I think with the features it gives it can't really be beaten, plus the proven Denon build quality is all there.
  4. danielw
    danielw
    Mar 3, 2007
    23
    cheers guys. yeah i was looking at the denon tuner and thinking that it had to be the best value and yeah the build quality of the denon is a lot better than the cambridge audio one and rotel is nearly twice the price!
