Help with converting s-video and rgb sources to component
Discussion in 'Cables & Switches' started by PeteCallaway, Aug 27, 2004.
  1. PeteCallaway
    PeteCallaway
    Jun 16, 2004
    9
    Cross posted from the Plasma and LCD forum when I realised this would probably be a better place to ask ;)
    Hi all,
    I'm trying to sort out the simplest way of getting a number of different sources to feed into the component inputs of my plasma screen.
    I have 2 x RGB Scart sources and 1 x s-video source.
    Is it possible to convert s-video to scart? I was thinking I could then feed this to an RGB to component box.
    Is there another, simpler way that I've not thought of?
    Thanks for any help
    Pete
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,311
    Rainham Essex
    +2,425
    Scart leads can carry several different signal types - composite, S-Video & RGB.
    RGB can easily be converted to component with a converter from companies such as www.js-technology.com but I am not aware of any standalone converters for S-Video to component. This can however be done by many of the newer AV receivers such as the Denon 3803/5 etc.
    Mark.
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,550
    The Borders
    +3,025
    PeteCallaway
    SCART is a type of AV Socket or Plug and a SCART Cable carries Video and/or Audio signals between two SCART sockets.
    A SCART Socket/Plug/Cable can carry Composite, S-Video and RGB Component video signals - depending on the source and receive kit being used (not all kit has all three options enabled).
    RGB Component signals (4 core) can be relatively cheaply (£150) converted to YUV Component (3 core) without loosing too much signal quality.
    Converting Composite and S-Video is another matter - you could use a low cost/quality stand alone unit (£100) to convert these signals to YUV Component though don't expect decent video pictures or as MarkE19 suggests many £500+ AV Receivers now offer this 'facility'.
    Better still is a proper Home Theatre Video Processor and the DVDO iScanPro (c£250) and iScanUltra (c£500) are the lowest cost/decent quality processors I'd suggest/use/supply - you can set them to output RGBHV or YUV Progressive Component video.
    See http://www.dvdo.com/pro/index.html
    I'd avoid your idea of converting Composite and S-Video to RGB+Composite (that's the flavour of RGB you get down SCART cables) and then converting that signal to YUV using an RGB2YUV converter - it would look horrid.
    If budget allows you could use the £950 DVDO iScanHD to convert RGB+C, S-Video and Composite signals to Progressive YUV or RGBHV - this will give you the best results by far.
    Best regards
    Joe
