Help with converting s-video and rgb sources to component
Discussion in 'Plasma TVs Forum' started by PeteCallaway, Aug 27, 2004.
  1. PeteCallaway
    PeteCallaway
    Jun 16, 2004
    9
    Hi all,
    I'm trying to sort out the simplest way of getting a number of different sources to feed into the component inputs of my plasma screen.
    I have 2 x RGB Scart sources and 1 x s-video source.
    Is it possible to convert s-video to scart? I was thinking I could then feed this to an RGB to component box.
    Is there another, simpler way that I've not thought of?
    Thanks for any help
    Pete
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
  3. PeteCallaway
    PeteCallaway
    Jun 16, 2004
    9
    Thanks for the reply.
    That's the kind of kit I had in mind, but I still need to convert s-video to RGB. Is that possible?
    Cheers,
    Pete
  4. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    why convert twice, Plasma monitors are VGA devices, so convert to VGA
    http://www.av-sales.com/html/zinwell_prov200.html £86
    this will convert S-video and composite to VGA, and has a tv tuner in it as well. Specs look fantastic, if it's as good as they say, buy this and the RGB to VGA plasma, and forget all about the panny input boards.
    Remember under UK mail order trading conditions, you can buy these
    and return them if not satisfactory within 7 working days from day after delivery, at no cost to yourself (except return postage)
