Help with connections!
Discussion in 'Xbox Forums' started by spidermanalf, Mar 22, 2006.
  1. spidermanalf
    spidermanalf
    Oct 25, 2002
    2,000
    63
    Wakefield
    +103
    I need a box where I can put in 3 scarts, 1 component, 1 VGA and one HDMI into it and only have one HDMI cable coming out!
    I know that joytech have one but cannot see from the pics what outputs there are!
    I have put it in here as the scarts etc mentioned above are for my games consoles going into my games room LCD!
    Any help would be appreciated!
  2. sbowler
    sbowler
    Mar 24, 2005
    3,799
    Leeds
    +481
  3. spidermanalf
    spidermanalf
    Oct 25, 2002
    2,000
    63
    Wakefield
    +103
    Cheers! Fellow Shakey Wakey bod!
    Had a look through but cannot really see anything that will do the job!
  4. John
    John
    Dec 13, 2002
    11,635
    +3,304
    Scart and component are analogue signals , HDMI is digital is it not ? Some sort of conversion is going to have to happen .
    Piers , Gordon , Joe and probably MAW are the guys that would know if such kit is available . Might be woth a post in the custom installer forum although they normally hang out in the Plasma forum ( Possibly even LCD , but I don't look in there that much to be sure )
    I see all those inputs , HDMI output and £ signs .
    Good luck
    John
  5. scumball
    scumball
    Jan 12, 2004
    6,526
    Harrow - London
    +451
    Some of the new Amps do format conversion and output HDMI...you won't get scarts but you could use composite/svideo/component - but as the man says ££. Denon AVR-3806 does the job for instance...
    HDMI Video Conversion
    Video, S-Video -> HDMI 480i/576i
    Component 480i/576i -> HDMI 480i/576i
    Component 480p/576p -> HDMI 480p/576p
    Component 720p -> HDMI 720p
    Component 1080i -> HDMI 1080i
    [​IMG]
  6. spidermanalf
    spidermanalf
    Oct 25, 2002
    2,000
    63
    Wakefield
    +103
    GRRRRRRRRRR thought as much! Cheers Guys anyway!
