Help with connections please
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by sdm197, Aug 18, 2004.
  1. sdm197
    sdm197
    Apr 21, 2003
    202
    South East London UK.
    +13
    :confused: Hi Everyone :hiya: ,
    I have a Yamaha DSP A1 which is great for watching DVD's but not as good as the Pioneer A400 for music. What I want to do is use both, which is possible using the pre outs of the Yamaha & connecting them to an input of the Pioneer (I think ) but this is the point I don't k now how to wire it up, does my CD player have to be connected to the Pioneer or can it stay connected to the Yamaha? are the speakers connected to the Yamaha or Pioneer? I read that you can combine the two so that I can listen to my CD player through the Pioneer and the Linn speakers, then also watch DVD's through the Yamaha and Linns without connecting or disconnecting wiring. I did consider a Qed system switcher which allows two amps to share the same set of speakers, but a hifi shop said it would degrade the signal as it was not up to the quality of the rest of the system. I would welcome any replies to tell me how to achieve the result I want. :lease:
    Steve.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Connect the front pre-outs of the Yamaha to any free line level input (e.g. AUX, Tuner, CD) of the Pioneer, using a standard interconnect cable (stereo).
    It can stay connected to the Yamaha but to bypass the Yamaha altogether you may connect the CDP directly to the stereo amp. Then the Yamaha can actually be switched off when you listen to CD-stereo only.
    Note: If you bypass the Yamaha you loose however all DSP modes and bassmanagement (i.e. no subwoofer used) etc.
    Front speakers to the Pioneer, all other speakers connected to the Yamaha.
  3. sdm197
    sdm197
    Apr 21, 2003
    202
    +13
    Thanks for the reply, most helpful
    Steve. :smashin:
