Help with connections into my amp
Discussion in 'AV Receivers & Amplifiers' started by wolfeh, Feb 21, 2003.
  1. wolfeh
    wolfeh
    Feb 21, 2003
    421
    Ramsgate, Kent
    +10
    :confused:
    hello, can anyone help me with a slight problem i have.
    i cant seem to get dolby digital/dts outta my ps2 and into my amp.
    I have connected my ps2 to my marantz sr4300 via an optical cable into the digital 1 port on the marantz. i have enabled the optical out on the ps2 and tried a variety of films and games. but, the marantz is only picking up left and right channel audio from the ps2. have i missed something? or have i broken something? :D
    i would be great full for any help
    thanks
    chris
  2. Gerry
    Gerry
    Oct 20, 2001
    251
    My Gaf
    +10
    When you have a DVD(movie) playing in the PS2 pause it. Then bring up a menu by pressing "Select" on the PS2 controller. Go into the "Setup" option on the menu and select "Audio". Check that the "Audio Digital Out" option is set to "On". When this is set to "ON" three more options appear, "Dolby Digital", "DTS" and MPEG". These options can be set to ON/OFF. Obviously set them to "ON"
  3. wolfeh
    wolfeh
    Feb 21, 2003
    421
    Ramsgate, Kent
    +10
    weeeeeee.....
    Thanks it worked great
    :clap:
    now im off to watch band of brothers :D
  4. Squirrel God
    Squirrel God
    Wolfeh,
    With regards the above, check your Marantz receiver has an MPEG-II decoder built in. If it doesn't, leave MPEG set to OFF. A PCM stream should then be sent to the receiver instead.
  5. nam
    nam
    Hi- I adjusted my PS2 using 'Setup', 'Audio', like you mentioned, and when I turned Dolby Digital to 'On' and played a dvd it came up 'Dolby digital 2/0'. When this was originally switched to 'Off' it said 'Digital Stereo' -but I couldn't hear a difference.
    What would the difference be?
    Thanks.
  6. Squirrel God
    Squirrel God
    If it's DD2.0 it might be DD2.0 surround.
  7. nam
    nam
    I thought Dolby Digital automatically meant 5.1 in stereo -what would Dolby Digital 2.0 be -it's a contradiction surely?
  8. Squirrel God
    Squirrel God
    No, Dolby Digital just means it's a digitally-encoded Dolby soundtrack which can be any number of channels, not necessarily 5.1.
    DD2.0 could be stereo, but it could also be Dolby Surround because the surround channels are encoded onto the L&R channels.
    I'm not even going to try explaining the Dolby numbering system because it's a terrible numbering system. But you can enjoy the confusion about it on this thread:
    http://www.avforums.com/forums/showthread.php?s=&threadid=68462 :D
