Help with connections for Home Cinema and Sky+?
Discussion in 'Home Cinema Buying & Building' started by TWISS, Jan 20, 2008.
  1. TWISS
    TWISS
    HI All,
    Looking for help and advice on the best way to connect up my AV equipment.
    I have (weak link) Panasonic Plasma TH 42-PE30 - Non HD
    Sky+ and just bought the LG HT902TB Home Cinema.
    I want the Sky+ to run through the Surround sound and get the optimum pic from the DVD and SKY.
    What cables do you recommend and how to connect to get the best picture and sound from all sources.
    Your assistance and advice would be very much appreciated.
  2. kentish_lad
    kentish_lad
    Sep 14, 2006
    1,627
    Kent
    +192
    I assume your TV hasnt got a HDMI input,
    Sky+ >> SCART (rgb)>> TV OR Sky+ >> component (rgb)>>TV
    Sky+ >> OPTICAL >> LG
  3. TWISS
    TWISS
    Hi Kentish_lad
    No it hasnt unfortunately.
    Thanks for the advice - I'll give that a go.
    Dave
