Help with connecting SONY SA-WD200 Subwoofer ;-p
S
Sheefa
Hi all,
I purchased a Sony SA-WD200 Subwoofer about 3 months ago and would like to link it up to my Sony MHC-WZ8d DVD Hi-Fi system.
I have done this using the Standard Subwoofer connecting lead, I have turned the Subwoofer on in the settings menu on-screen and also turned the volume up to the maximum 10db setting, but sadly there is very little power coming through the subwoofer when I play music or a film.
I then tried hooking the subwoofer up via the speaker in and out terminals and this was much better - louder sound and clearer clarity. The trouble is, on the speaker terminal in port, I can't find a suitable connector to hold the speaker cables in place - I have to use bluetac!. It is a white plug that sticks out a little with a number of solid metal connection points inside. Can you help me and let me know what the type of cable I need is to ensure a secure connection?
I have attached a couple of images of the plug if this helps. Hope you can help.
Many thanks.
Greg Wheatley. :thumbsup:
