Help with connecting my LCD to PC & Stereo
Discussion in 'LCD & LED LCD TVs Forum' started by ben0l0, Jul 24, 2005.
Tags:
  1. ben0l0
    ben0l0
    I am hoping someone is able to help me. I have bought myself a budget LCD tv to replace both my old tv and my computer monitor. I have tuned in the TV but realised I need a VGA lead (????) to connect it to my pc, is that right?
    I have a seperates system (Tuner, cd player and amp) , and want to use to use that as the sound for both my PC and TV, can anyone tell me how that is done. What I need to connect to what and the leads
    many thanks
  2. craigdyer
    craigdyer
    Hi yes you will need a VGA to VGA lead I think it is the male to male lead you will need.
    On the sound front you can pick up a lead not sure what the name is but one end looks like a headphone jack and this plugs into the PC sound card and the other end has two RCA plugs coloured red and white and these plug into your amp usualy labeled AUX in. hope this helps.
