Help with connecting multiple devices, eg TV, VIDEO/DVD PLAYER, HD SET TOP BOX
Discussion in 'Home Cinema Buying & Building' started by easynice, Jun 7, 2008.
  1. easynice
    easynice
    Feb 24, 2008
    7
    Hi, I am having problems connecting my devices together, I live in Australia and we do not use scarts. I have a 19' Samsung LA19R7 TV, a Samsung dvd/ video combi DVD-V6800 and a DGTEC High def set top box DG-HD3800. At the moment i have the coax from outside ariel going to the HD set top box, An HDMI from tv to set top box and this works ok, when i try to connect the dvd/video combi i get a bit confused. Any Help would be great thanks.
    :lease:
  2. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    i think that dvd/video combi has component out(red-blue-green),for video..so if the tv has them,as inputs..use them.
  3. easynice
    easynice
    Feb 24, 2008
    7
    Hi thanks, have sorted this out now. Dont suppose anybody has a region crack for the Samsung DVD V6800, It is region 4 at the moment. Cheers in advance.
