Help with connecting DVD/NTL/Xbox to my new TV...
Discussion in 'Cable TV & Virgin Media TV' started by Morph3ous, Aug 8, 2005.
  1. Morph3ous
    Morph3ous
    Aug 3, 2005
    43
    Norfolk
    I have recently upgraded my TV to a new Toshiba 36ZP46. I would like to get the best possible picture from my NTL Cable TV, DVD player and XBOX.
    I've been reading a few threads and have noticed mentions of RGB, Composite, Progressive Scan etc etc.
    My TV has 3 Scart Connectors (2 of which are RGB)
    Component Video Input
    Composite Video Input
    S-Video Input
    IT also supports Progressive Scan
    At present I have an old Samsung 709 DVD player (which supports RGB), but mat be upgrading this to a Pioneer DV-575A (which has both RGB and Component outputs, and supports Progressive Scan).
    I will be connecting everything up to a Yamaha AV Receiver, but i'm fine with the Audio side of things. I just need some help with the Video.
    MY questions are:
    1) What is the difference between RGB input and Component input? Which is the best to go for?
    2) What is and should i make use of 'Progressive Scan'?
    3) What would be the best way to connect the whole lot up, giving the best picture quality?
    I would like a balance between 'best picture' and price of new leads, as we're moving house and on a tight budget.
    Any advice on how to hook it all up and what cables to use would be most helpful.
    Cheers,
    Morph3ous.
  2. Morph3ous
    Morph3ous
    Aug 3, 2005
    43
    Norfolk
    While i'm here, I may as well seek some 'Professional' advice on how to connect my VCR too...
    Just to make things clear,
    I want to connect a DVD/Cable TV/VCR/Xbox to my TV.
    As i said above, the TV has 3 x scarts 2 of which are RGB.
    Advice on how to connect for best picture as i said above, and also for ease of use when recording Cable onto VCR would be greatly apreciated.
    Morph3ous
  3. Morph3ous
    Morph3ous
    Aug 3, 2005
    43
    Norfolk
    Please see my other tread titled, 'All thats needed now is to figure how to connect up the TV signal?!!?' before replying...
    thanks
    Morph3ous
