Help with connecting B.F.D.
Discussion in 'Cables & Switches' started by BarryK, Jun 25, 2003.
  1. BarryK
    BarryK
    Nov 18, 2001
    93
    Hi all,
    I have recently purchased a BFD Pro DSP 1124P. I wish to connect it to my Velodyne CHT-15 sub, using a phono cable. With the BFD not having any phono input/outputs I therefore require an adaptor.
    Does anyone have any information on the adaptor I require?
    Would a 6.35mm Plug to Phono Socket adaptor from maplins do the job. (Part No:- KW36P or RW01B)
    Thanking you in anticipation
    Barry
  2. dunkyboy
    dunkyboy
    Jun 5, 2002
    635
    London
    +6
    Barry, sorry to butt in on your thread, but may I ask where you ordered your BFD from? I ordered one from www.soundslive.co.uk, but it turned out it's actually out of stock there. I'd like to cancel if I can find somewhere that *does* have it in stock...
    Cheers,
    Dunc
  3. BarryK
    BarryK
    Nov 18, 2001
    93
    I ordered mine from `hwaudio.co.uk`
    Ordered on the 19th June and was told none in stock. Arrived today though.
    Barry
  4. dunkyboy
    dunkyboy
    Jun 5, 2002
    635
    London
    +6
    Thanks! :smashin:
  5. Free
    Free
    I use these to connect mine.
  6. lmccauley
    lmccauley
    Oct 24, 2000
    3,440
    Newcastle
    +275
  7. kenlong69
    kenlong69
    Oct 24, 2002
    508
    Doha
    +6
    Hey there!
    I use the Maplin Ones as well. They work a treat!
    Ken
  8. BarryK
    BarryK
    Nov 18, 2001
    93
    Thank you very much guys. I will order some today.
    Barry
