Help with component connection
Parklife
Just got my PS3 from Hong Kong and cannot get it working using component. I am using my old PS2 component cable and when I switch the display settings to component I get no picture. All I can get at the moment is composite.
Does the PS2 component cable work or do I need a new one for the PS3?
T
TLT
How come you dint get one with the ps3 as these come as standard?
Parklife
No idea. No component cable included...just a composite cable.
bravo1306
I bought a jap PS3, as far as I'm aware all PS3 only ship with composite AV cables. I got mine working with my PS2 component cable.
Try powering off your PS3 then when powering on hold the I/O (on/off) button for about 6 seconds, the PS3 will beep and will reset the default output options.
Have you updated your PS3 firmware (1.2 or 1.3) ?
Parklife
Decided yesterday tp try another component cable.....and for some mysterious reason it worked!!!
Similar threads
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
