Help with choosing cables please
Discussion in 'LCD & LED LCD TVs' started by deadred, Jan 7, 2005.
  1. deadred
    deadred
    Nov 18, 2004
    2,542
    71
    Cumbria
    +90
    I've just ordered a Sharp LC26GA4E and a Panasonic TU-CT30 freeview box, i was wondering the best way to connect, and which cables to use? Can anyone recomend any thanks :lease:
  2. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    Take a look through the manual for the freeview box to find which scart socket enables RGB. Plug a fully wired SCART into this and plug the other end into an RGB SCART socket in the LCD (SCART 1 I think).
    You might have to go into the Freeview box's option to set the signal to RGB and will you deffinately have to do it on the LCD.
    Others say S-Video is about the same quality but try either way.
    HTH,
    Richie.
  3. deadred
    deadred
    Nov 18, 2004
    2,542
    71
    Cumbria
    +90
    Thanks Rich, i'll have to wait till Monday though as that's when it arrives, i was hoping to get everything ready for then so i could set it up straight away, sit back and admire :thumbsup:
  4. ginger
    ginger
    If you see some noise on your picture consider investing in a decent SCART cable. The one you will have got with the box will be crap. Apparently if you spend just £6 it will make a noticeable difference. I spent £55 on the IXOS XHT801-150 and definitely noticed an improvement in noise (gone) and sound quality. QED do similarly priced cables - you can get them cheaper than what I paid, but I wanted it quickly and went for somewhere that had it in stock
  5. deadred
    deadred
    Nov 18, 2004
    2,542
    71
    Cumbria
    +90
    What about hooking up an RF signal should i buy a better one (gold) or will it not make that much difference?
  6. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Looking for good quality scarts, take a looka t the £5.99 Flat cable scarts at www.tvcables.co.uk
    Really unbelievable quality for a rediculous price. Vastly superior to the nasty plastic freebies, but probably not as spiffing as the silly money ones...
    Good RF cables might be a good idea, because a good terrestrial signal can still be very rewarding.
    Jimmy
  7. deadred
    deadred
    Nov 18, 2004
    2,542
    71
    Cumbria
    +90
    Cheers Jim, just ordered 2 of them beauties!
