Help with choosing a digital camcorder
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by emma133, Jul 10, 2004.
  1. emma133
    emma133
    Hello, well i must say i feel a little out of depth, my analogue camcorder has finally given way, and i would like to now upgrade to a digital camcorder. However i have a set budget which is rather small, but i would like to know what to look for and where to start! The camcorder will be used for just family shots, like the childrens birthdays, christmas, school concerts etc. I have tried to do a little research my self, but have ended up rather confused. I would be extremely gratefull for any help and advice. :lease:
  2. El Indio
    El Indio
    Jan 1, 2003
    35
    In other words you want a cheap camera that can shoot good video in difficult (low light) situations - dont we all :)
    Why dont you try checking the several review magazines in the newsagent (if u live in UK) to get an idea of whats avaliable at your budget?
  3. emma133
    emma133
    i have been checking some websites, but unfortunately i'm not very technical, so i don't really know what i should be looking for, i have budgeted around £250. Which i know isn't much, but i would like something i could use with the pc.
  4. Blu Ray
    Blu Ray
    Jun 14, 2004
    496
    Chorley, Lancs
    +12
    If you want to download to your PC then an 'I-link' (firewire, DV-out) is important. Also, do you want it to be backwards compatible with your old tapes? Reason for asking this, is if you have a stack of Hi-8 tapes that you want to be able to archive, then you need to go for a Digital 8 that plays back the old format.
  5. emma133
    emma133
    Right, thanks for the reply, yes i do have old analogue tapes. I had narrowed it down to 3 within my price range, then got completely confused because they also have the E models (all three are sony) so i now have to find out what the E models are. Getting more and more confused each day.
  6. Blu Ray
    Blu Ray
    Jun 14, 2004
    496
    Chorley, Lancs
    +12
    Well, the DCRTRV460E plays back old 8mm for sure, that's about £360 though. I think, but I'm not certain, that the 'E' just means European.
