Help with capturing footage from Digital8
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by gurthod, Mar 31, 2005.
  1. gurthod
    gurthod
    Mar 25, 2005
    14
    I've got some footage on a Sony Handycam on Digiatal8 tape. After reading many threads on this website I feel I have everything in place to capture the footage to PC for simple editing ........however, it still does not work.
    Any suggestions?
  2. DigiStuff
    DigiStuff
    Jan 22, 2002
    151
    Hi gurthod,
    I think you will need to give us some more information as to what is going wrong. Please tell us your model of camcorder, editing software and hardware, PC spec, operating system used and exactly what is not working.
    Then some one will be able to help you out I am sure!!
    DigiStuff
  3. gurthod
    gurthod
    Mar 25, 2005
    14
    OK. I've got a Sony Digital Handycam DCR-TRV145E. I've got footage on Hi8 and Digital8 tape. My PC is fairly decent spec (2.4 GHertz, 512 MB RAM, 264MB Graphics Card) as it's only about 6 months old. I'm running XP SP2. I recently bought a Firewire card which came with a cable for the DV out on the handycam. I first tried to use Movie Maker but it didn't recognise that i'd even installed the card although XP told me the hardware was installed and working properly. I then acquired a trial of Pinnacle Studio 8 (which has now run out), but when i went to capture i kept getting an error message saying that the handycam needed to be switched on etc (which it was!).
    Hope you can help
    gurthod
  4. melliott1963
    melliott1963
    Nov 27, 2001
    427
    Ilford, Essex
    +4
    OK, try this . . .
    What happens if, without going into any program, you just connect your camcorder (make sure it's in VCR mode) and turn it on? If you hear a sound (on my PC it's a couple of 'musical' beeps), then it means that your PC has recognised that something is attached. If you don't hear anything, then it could be that you've got a faulty firewire cable, or maybe you're firewire card isn't correctly working (despite what XP tells you!).
    Have you got access to another PC with a Firewire connection (i.e. at work or a friend)? If so, then it might be worth trying out connecting you camcorder to that PC, just to rule out the possibility of the DV socket on the camcorder being faulty.
    Let us know how you get on.
  5. hao
    hao
  6. melliott1963
    melliott1963
    Nov 27, 2001
    427
    Ilford, Essex
    +4
  7. gurthod
    gurthod
    Mar 25, 2005
    14
    Cheers for your help guys.
    A mate of mine is going to bring round his Firewire cable this weekend, at least then i'll know if that's the problem. If it still doesn't work i'll have to try and find someone who has a firewire connection on their PC that they know works. Sounds like i am doing the right thing, just need to get to the root of the problem by elimination.
    Thanks again
    gurthod
