Help with cable for Geforce 7800 GT
Discussion in 'Desktop & Laptop Computers Forum' started by TheDoctor, Sep 4, 2005.
  1. TheDoctor
    TheDoctor
    Aug 31, 2004
    389
    28
    +42
    Hello All
    I have ordered a PC with an Nvidia 7800 GT graphics card. My plan is to connect it to my Pioneer 505XDE via it's VGA input. It will be used to play HD content.
    I need some help regarding the best cable to use and where to get it from (length required will be 10m).
    Should I get a DVI-D to DVI-D cable and use a VGA adapter at the plasma end?
    Any advice would be welcome.
    Doc
  2. Rambles
    Rambles
    Jul 14, 2004
    8,293
    UK
    +1,276
    No, don't think there is much point in that - has the graphics card not get a VGA out port? If so good quality VGA to VGA cable should be better, no conversion, everything stays analogue.
  3. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    If there isn't a VGA output, what you will need is a DVI-I to DVI-I cable with a DVI-I to VGA converter.
    DVI-D only sends Digital signals and doesn't have as many pins as the DVI-I. DVI-I can send either digital or analogue signals.
    Another way around it is getting a DVI-I to VGA converter and then a VGA cable.
    Take a look at www.lindy.co.uk
    HTH,
    Richie.
  4. Xelon
    Xelon
    Nov 16, 2004
    391
    +53
    My 7800GTX has 2 DVI's and comes with 2 DVI - Dsub (VGA) converters, maybe the samse with the GT?
  5. TheDoctor
    TheDoctor
    Aug 31, 2004
    389
    28
    +42
    Thanks for your help guys, I'm going for the "silver serpent" VGA cable (8m) and will use the DVI to VGA convertor that will come with the card.
    All the best
    Doc
