Help with buying a plasma!
Discussion in 'Plasma TVs Forum' started by dbedgood, Feb 9, 2005.
  1. dbedgood
    dbedgood
    Oct 15, 2004
    64
    I am thinking of buying a Panasonic TH37PW7 plasma from Richer Sounds. To go with it I'm also thinking of buying a Yamaha DSPAX750 Amp and Kef KHT2005.2 surround sound system. The problem I'm having is with the cards for the plasma screen, I need to connect my DVD which has component outputs and also a Sky box and XBOX will need to be connected to it. Would it be better to get a component terminal card and a scart terminal card for the plasma with possibly a junction scart box? Also does anyone know if I have to buy the panasonic terminal cards or are there alternatives?
    Thanks for your time
    Damon
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    you have to buy panasonic terminal cards (some TOSH rebranded ones will work) the JS RGB>VGA converter is a higher quality option than panny scart board have a read of the many many PW7 threads around here and this one particularly:http://www.avforums.com/forums/showthread.php?t=154292 long but contains all you need!
    PS there are better places to buy than RS...............
  3. dbedgood
    dbedgood
    Oct 15, 2004
    64
    Thanks for the reply hornydragon.
    I have checked out the thread and they basically mention to get the js rgb converter, however I want to be able to add a couple of RGB's i.e. video, Sky etc what would I need for that and also are there any higher quality component boards like the js rgb converter which I could also add to the plasma?
    Appreciate the help
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    OK VCR is not RGB but Composite or S-video if an S-VHS deck..... JS converters only work with RGB... What do actually own?
  5. dbedgood
    dbedgood
    Oct 15, 2004
    64
    I own a video which is scart, the cable digital box will be scart, Xbox will also be scart. My DVD player can output component.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    sounds to me like you need a scart card for cable and VCR XBOX can also do component so add a component card for DVD and Xbox (you will need sound so look for an AV Amp with component switching) Entry level Yamaha, Denon and Pionner etc £200 ish upwards
  7. dbedgood
    dbedgood
    Oct 15, 2004
    64
    So I need to basically buy a scart card and component card for the plasma screen, the amp I'm getting (Yamaha DSPAX750) has component switching so that should do it.
    Thanks for your help.
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    AVsales have a cracking offer on teh 37" with tuner unit essentially free!!! this can be sold for £200+ on ebay so will cover cost of scart and component board......
  9. tetrarch
    tetrarch
    Jan 20, 2005
    60
    Doesn't the Crystaltec offer cap that £1194 plus free scart board without the eBay hassle ?
    That, of course if they are selling the same product !!
    http://crystaltec.co.uk/showitem.php?pid=733
    Regards
    Tet
    Settled on 37" Panny
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    on price yes but not if you want any of the fancier boards (HDMI for example) or if you want an extended warranty............
