Help with buying a new DVD recorder
Discussion in 'Blu-ray & DVD Players & Recorders' started by Dan Baker, Dec 4, 2004.
  1. Dan Baker
    Dan Baker
    Dec 4, 2004
    3,277
    Dorset
    +606
    All,
    I am looking to buy my parents a DVD recorder for christmas, with the aims that they could use this in their bedroom for recording programs and watching DVD's as they do not yet own a DVD player.
    Some criteria I am hoping to meet in order of most important,
    1) They currently view sky to their room from the digibox in the living room and using one of those magic eyes to change the channels. I would like them to be able to record sky from their room onto DVD.
    2) I would like the recorder to be able to record to all formats i.e DVDR, DVDRW and DVDRAM.
    3) I'm hoping to keep the price range from 200-350 pounds.
    4) A couple of bonus feature would be a ilink connection and multi-region support.
    Models I've considered so far are,
    JVC - DRM10
    Toshiba - DR3
    Samgsung - R100
    Criteria number one is really the big one to meet for me but aftewr research I'm still unsure of exactly how possible this is.
    Any help or pointers will be greater appreciated.
    Many Thanks and apologies for any typos in advance.
  2. Dan Baker
    Dan Baker
    Dec 4, 2004
    3,277
    Dorset
    +606
    Hmmm this is really started to get confussing after many hours of scouring the net and this forum I'm now interested in the Sony RDR-GX3 and Panny E55 as well as my above choices.
    Really starting to get confused though as I'm not sure if any of the machines can meet my number one criteria.
    Any nudges in the right direction would be fantastic.
    I really never though this could get so complicated I knew I should have bought them slippers.
  3. SDHoward
    SDHoward
    Nov 1, 2004
    250
    For 350 (well a tiny bit over) you could get a toshiba sx32 and therefore a model with a hard drive, save them having to keep finding blank dvd's all the time etc.. worth considering
  4. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    Sony GX3 is around 250 at comet.Just bought one myself.
    One thing that no-one mentions is that.....
    1.You have to format the disc
    2.After recording write it
    3.To play on another dvd player finalise it.
    all takes up time,only minutes,but its not like a vcr just put in a vid and record.
    As for GX3,there is a very slight hum,but the picture quality is very good.
  5. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
  6. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    finally,gx3 has been superceeded recently by a newer sony model.
  7. Dan Baker
    Dan Baker
    Dec 4, 2004
    3,277
    Dorset
    +606
    Paul,
    Thanks for the advise. Do you know if the Sony would be able to record SKY program despite the fact the digibox is in another room?
    Thanks in advance.
    Dan.
  8. geeWcee
    geeWcee
    Oct 27, 2003
    1,420
    West Yorkshire
    +26
    The Sony GX7 is the higher spec model to the GX3 and has the ilink connection you were hoping for at a slightly higher price. RGB direct are selling it for £288.
  9. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    dont have sky so cant say.
  10. Dan Baker
    Dan Baker
    Dec 4, 2004
    3,277
    Dorset
    +606
    Many thanks for all your help with this guys.
    I'm still not 100% But I've disregarded the Panny now as RAM discs are not compatible with our other DVD players.
    Its probably a toss up between the Samsung and Sony Models unless anyone can give me a good reason not to lean that way.
    Thanks again for all the help. I'll do my best to contribute back to the forums. :smashin:
  11. paulr
    paulr
    Jun 5, 2002
    1,159
    North Lincs
    +65
    The only other thing i'd say is look at the recording time of those with hard drives.My Sony only records 1 hour high quality on a normal dvd-rw but up to 6 hours low quality.
    With a hard drive there's no issue about formatting,loading i guess.(i dont think so anyway)
  12. GoldFish
    GoldFish
    Nov 4, 2002
    97
    9
    Bradford
  13. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    If sky is distibuted by an rf cable the recording quality will be relatively poor and the sound will of course be mono only. The recorder needs to be connected directly to the digibox.
    Buy a cheep player if they also need a dvd player in the bedroom
