Hello all,
After posting in the subwoofer forum I have ended up here because I am hoping that by going DIY I can get more bass without reducing the size of the floor area in my home cinema room.
I want to replace my 2x Tannoy SFX ported subs with 2x new non-ported subs, with 15" drivers. I know that the move from my current 8" subs to 15" will give me deeper bass, but with my current setup will I be leaving a noticeable hole in the bass response between the subs and my Wharfedale speakers?
Looking at turn-key subwoofers they are mostly cubed shaped. By going bigger on the driver front gives me a bigger cube. I'm hoping that by going rectangle-cube I can keep the volume the same but the depth to 300mm.
In my DIY search I found the self-build IPL SW6 Mk2. Specs are 445 by 445 by 440mm, 60 litre 25mm MDF. If I were to go 300mm deep and H&W of roughly 545mm and using the same 25mm MDF, I have roughly the same volume.
Is there anything else I should be considering? Does the rectangle shape alter bass dynamics over the cube design? I am already thinking that this design will make the box more unstable so I would secure it to the wall behind to stop movement.
Having built other simple speaker enclosures and furniture for my HC I am willing to give this a go, although with the much higher forces involved with moving more air then I would welcome suggestions or links to websites about building methods. At the moment I have only been using a jigsaw and getting B&Q to cut MDF to the straight line shapes I need. If fancy cabinet joins are better then perhaps there are people out there that will build custom size sub enclosures?
Once confirmed that I can go down this route then it will be a quest for drivers and an amp. Seeing other posts on here I'm already liking the idea of a Behringer amp.
Please see below for more information on my HC room.
Thanks!
Detailed Overview:
In January this year I embarked on upgrading my dedicated home cinema room. I would prefer to have a room 3 times the size but I feel fortunate enough to actually have a room that I can use purely for this one hobby and also one that I don't really have to worry about high sound levels being as the house is detached.
The size and shape of the room has meant I have had to make compromises, but I feel I've managed to make the best of the situation.
Compromise 1: Seating - against back wall - would rather have in the middle of a much larger room for surround sound distance.
The room has a cottage style window (shown on the right of my simple plan). This also means a stepped down ceiling which also slopes down. It was easier and cheaper for the house builders to box in that part of room. I used that wasted space to fit MDF cubes (shown in orange) to house the AV kit, PC and gaming consoles etc. Ceiling height in the tallest part of the room is 2.3m. As I mentioned previously, the ceiling steps down and also slopes so it is difficult to calculate the exact volume of the room.
I've managed to install 4 ceiling and 4 surround speakers, so giving me a Dolby Atmos 7.2.4 configuration.
Equipment:
Denon AVR-X3600
BenQ W2700 Projector
Pro-Ject Amp Box S2 Stereo Power Amplifier (to drive those extra 2 channels)
Tannoy SFX Subs
Wharfedale speakers (Surrounds are in-wall WCM-65's)
I've built custom furniture in order to house in-wall speakers & lighting and provide sound absorption. They are as follows:
1.5m x 1.2m x 10cm box - attached to ceiling
Box for centre speaker to sit on
Wall mounted shelving and box providing housing for in-wall surround speaker (shown in brown on plan)
The sound absorption I have used is rockwool and the outer covering is sound transparent material to allow sound to pass through. As I created and installed each piece of furniture it was amazing to hear the difference the absorption made to the sound in the room. The room originally had a wooden floor and there was quite a bit of bass boom and echo with voices - the sound absorption in the furniture pretty much eliminated this - to my amateur ears anyway!
The flooring is now carpet with 11mm Cloud 9 underlay. I was expecting the carpet to absorb some of the bass from the Tannoy's and it certainly has done that. Better performing subs have always been on my radar and now is the time that I am wanting to upgrade.
Not to scale
Key:
Red - Wharfedale Diamond 230 Floor Standing Speaker
Green - Wharfedale Diamond 11.CS Centre Speaker sat on home-made box stand incorporating sound absorption material
Yellow - Tannoy SFX Subwoofer
Pink - 90" Screen
Orange - AV equipment housed in home-made boxed enclosure recessed in wall
Brown - homemade shelving also housing surround speaker and sound absorption material.
Blue - Main listening position (projector mounted above this position)
Thanks!
Detailed Overview:
Equipment:
Denon AVR-X3600
Tannoy SFX Subs
Not to scale
Key:
Pink - 90" Screen
