Help with BG800 scan fail
Discussion in 'Projectors, Screens & Video Processors' started by bms2895, Apr 24, 2005.
  1. bms2895
    bms2895
    Hi, hope someone can help me with my Barco Graphics 800. I removed the green tube to clean behind the glass because of fungus and reinstalled everything and now it wont start. It will power on but will not project anything, and I am getting a scan fail. Also the l.e.d. marked HTHD flickers on and off in sync with a clicking sound. Has anyone had this problem before? It should be an easy fix because I dont think I broke anything or shorted anything out. Any help would be greatly appreciated, Thanks, Chris.
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    try removing the eht lead and end stage to see the projector powers up.
    It is possible you cracked the lead whe you took it out.
    If that works change the hole the eht lead is plugged into.
  3. bms2895
    bms2895
    Roland, Thanks for trying to help with this problem. I did what you said but there is no change in the way it reacts, (with the lead on or off). Is there anywhere that I might be able to download a service manual or a schematic? It is possible that I could have something hooked up wrong. Any other advise would be appreciated. Thanks again, Chris.
  4. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Doesn't sound like the tube it must be a connector that you have dislodged.
  5. bms2895
    bms2895
    I have checked and re-checked every possible connecter on this unit and everything has a good connection. I have pulled every board and every connection to check for mis-aligned pins, loose wires ect. and can't find anything. Is it possible that I damaged the tube somehow?
