Help with Bezel for Touchscreen
Discussion in 'Desktop & Laptop Computers Forum' started by JSW, Mar 19, 2003.
  1. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    Thanks to loonatic I have just took delivery of a superb 17" 3M Microtouch Touchscreen TFT display :D
    This one: http://www.barcodediscount.com/pdf/3M-MicroTouch/fpdchassis.pdf
    Unfortunately it dosen't come with the bezel you see in the pic so does anybody know where I could get one from in the UK?
    or would it be simple enough to diy?
    Also:
    How do I integrate it into my HTPC?
    I currently have the AE100 PJ connected to the vga out of the radeon 9700pro, so would i just connect the touchscreen to the dvi out with the dvi to vga adaptor ??
    Both screens are unlikely to be on at the same time.
    the touchscreen is for the music side of the htpc so i don't have to have the PJ on.
    Help and advice much appreciated :)
    Bry
  2. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
