Help With Barco 701s Green Tube
Discussion in 'Projectors, Screens & Video Processors' started by aerobic247, Mar 13, 2005.
  1. aerobic247
    aerobic247
    Jun 29, 2004
    181
    East Kilbride/Glasgow
    +13
    Hi i have had my Barco for three months working with out a hitch un till the green tube stopped producing an image.
    I lifted the lid took a look at the base of the green tube and it's producing an orange glow the same as the other tubes.
    I have tried swapping the yellow wires on the rgb amplifier but the green tube is still not producing an image.
    I am at loss on how to fix this any help is apreseated. :lease:
  2. ledoctt
    ledoctt
    Hi aerobic, you probably have problems with your RGB output amplifier. Sometimes the IC VPH 05 can breaked or some little transistor CMS.......
    Try to find a nother RGB amplifier......;
  3. aerobic247
    aerobic247
    Jun 29, 2004
    181
    +13
    Ok i disconnected the green and blue rgb amplifiers from the tubes and focus block then swopped them over and the problem moved from green to blue.
    all i need is a new one :thumbsup:
    I have Emailed Liam & Henry @ CRTprojectors on a price for one.
    I tried to email Roland @ B4projectors thru his web site but all i got was "File Not Found - Error 404"
  4. aerobic247
    aerobic247
    Jun 29, 2004
    181
    +13
    I got a reply from henry at crtprojectors they are out of rgb amplifier boards. :(
    any one out there no ware i can get one?
  5. GagHalfrunt
    GagHalfrunt
    Sep 1, 2001
    529
    North Cotswolds
    +3
    That's because he has all the Forward Slashes (/) as backslashes (\) in this code. So it will only work properly in evil IE.
    If you edit the URL to change the %5C to / it will work.
  6. aerobic247
    aerobic247
    Jun 29, 2004
    181
    +13
    That's wat i get for using Firefox internet explorer. :oops:
  7. aerobic247
    aerobic247
    Jun 29, 2004
    181
    +13
    I tried www.hammerheadtech.com for a second hand r762559 rgb amplifier got a reply from stating "we don't have that model in stock, but we do have another part number in stock that will work with the 701s. I just want to make sure you didn't need that exact part number and you were just looking for a part that should work with all 701s sets. "
    Is this true are there other rgb amplifier boards that will work with my projector?
    :confused:
  8. GagHalfrunt
    GagHalfrunt
    Sep 1, 2001
    529
    North Cotswolds
    +3
    You can't blame a web browser for a wrongly written web page. :lesson:
  9. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Ok I'm working on it. BARE ;) with me
    aerobic247 I have one if you still need it. [email protected]
  10. GagHalfrunt
    GagHalfrunt
    Sep 1, 2001
    529
    North Cotswolds
    +3
    I really don't want to see you like that. :)
    The only thing that's really wrong with it is that you have "\" instead of "/" in your links. Change those and it will work. IE lets you get away with this bad practice.
  11. aerobic247
    aerobic247
    Jun 29, 2004
    181
    +13
    Hi Roland i have emailed you about the rgb amp thanks. I tried www.hammerheadtech.com/ they asked for R number of the projector witch i gave them R9000730 they checked there barco data spreadsheet and set me an rgb amp R9000716 but it did not fit :mad: . I down loaded a copy of the spreadsheet and shoore enuff there's according to the spreadsheet it shood be the right part at firtst i thought my projector was a hybred machine made up different parts but the all the serial numbers in my projector ar the same. can any one spread some light on this :suicide:
  12. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Hi I'll catch up with emails later today.
    Have you got the actual part numbers (ie the 76****) printed on the boards
  13. aerobic247
    aerobic247
    Jun 29, 2004
    181
    +13
    Roland the number on the board is 762559
  14. aerobic247
    aerobic247
    Jun 29, 2004
    181
    +13
    I received a new rgb amp this morning from Roland. :thumbsup:
    I installed the board and my projector is now up and running after being down for a month :clap:
    I nipped out and got a copy of the incredibles a big bag of popcorn and sat down to watch a movie i have been dying to see and wouldn't you no it my dvd player chosed that f:censored:king moment to pack in and give up the gost :suicide: Have any of you ever seen a grown man cry?
