Dom1984
I've recently purchased a Yamaha RV-V377 AV receiver and Tannoy HTS101 5.1 speaker system.
I was just wondering what general settings people are using, for movies and music etc?
(Movie, Music, Surround decode, and Straight are the modes I have to play with)
Does it switch to DTS/DTS HD mode automatically?
Also, could someone explain a little about my sound card settings, I can go into the sound card properties, and change the format from 16-bit 32000Hz - 24-bit 192000Hz.
Now, as soon as I switch to anything above 96000Hz (24-bit 96000Hz is the highest I can set it to without having the modes restricted), it disables the surround decode and movie/music modes on my receiver and locks it into "Straight mode".
Why is this and what should I set it to?
Also, when configuring my speakers in windows, should the satellites be set as full range speakers?
I don't have a sound card in my computer, I'm going straight from my PC to the receiver using HDMI, is there anything I should be doing to set it up correctly, so that my receiver is doing all the work and is getting the cleanest possible sound?
Also, the surround decoder settings are Pro Logic and Neo 6, which is best?
My computer is the only input, so want to get it all setup and tweaked as best I can.
Would the "straight" mode always be better, and if I used that would it automatically switch between the sources original audio format DTS/DTS-HD etc? According to the copy I was using (DVD, BLUE-RAY etc).
Any help appreciated,
Cheers.
Cheers.
