Help with AV AMP
Discussion in 'AV Receivers & Amplifiers' started by petrolhead, Jan 7, 2003.
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +115
    Not for me.
    What would you suggest as a Good AV Amp.
    Must have DPLII and EX and good with sterio music.
    Max budget £500
  2. adox
    adox
    Nov 5, 2002
    688
    19
    dublin
    try the new marantz range. they have dpl2 and are good with music. i have the entry level sr4300 and bought it with the intention of using it 50% for music, and am quite pleased with it. i think the sr5300 or sr7300 are more in the price range you are looking at. they all have es ex etc. as well!
  3. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    ALso have a look at the Denon AV1803 and 2803...both are good value and have all the features you've spec'd.
  4. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +115
    Adox
    I thought the 4300 has es and ex?
  5. adox
    adox
    Nov 5, 2002
    688
    19
    dublin
    yeah it does. the whole range have. sorry if i didn`t make that clear
  6. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +115
    so whats the difference between the 4300 and 5300
  7. adox
    adox
    Nov 5, 2002
    688
    19
    dublin
    i think about 10 watts per channel. the sr4300 has 6 x 80 watts and the sr 5300 is about 90 or 95 watts per channel.
    as far as i know that`s the only difference.
  8. 7ThGuest
    7ThGuest
    SR 4300 239:95 at RS today 'Managers Special' 'cos they've got no 4200's :) :)
    Don't know if that is just the Newcastle branch though??
    Regards
    7ThGuest
    Thx petrolhead
  9. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +115
    So folks there you have it.
    A new 4300 owner.
