Help with av amp for £300!!
Discussion in 'AV Receivers & Amplifiers' started by 117, Feb 4, 2009.
  1. 117
    117
    Sep 19, 2006
    49
    +3
    Hi guys,
    At the moment my father has an Onkyo TX-SR504 which isnt a bad amp but lacks HDMI and displays 'overheat' whenever it is turned up relatively loud and a film requires a dynamically powerful output, presumably because the tv rack only has about 5cm ventilation space above the unit.
    With a budget of £300 I am looking for an amp which meets the following criteria -
    3 HDMI Inputs minimum that will carry audio
    Relatively low heat output, eg will operate in the current location without turning itself off!
    Will work seamlessly with a Logitech Harmony One
    I have looked at the Sony STR-DG820 and the Denon 1909, although have heard that the Denon can cause problems with the Harmony remote, and I will be doing the installation so the fewer problems the better!
    All advice is appreciated, cheers guys.
  2. Oily
    Oily
    Jun 11, 2007
    1,062
    Radcliffe
    +83
    I've just bought an Onkyo 606,has 4 HDMI inputs,being used in a semi confined space,no problems as yet with heat etc and it works with my Harmony One :smashin:
